mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
Grievous
Sep 20, 2010Aspirant
Not sure why we're discussing 4k sectors, but whatever.
I need a volunteer or two. Specifically running 4.2.13, showing the temperature out of spec, and letting us have SSH access to the system(contact me via PM and we'll arrange it that way), as we need to remotely verify that the fans are operating accordingly, or if there's a separate issue with the reported fan speed. Your data will be intact during the duration and you'll have access to it. Also, instead of remotely rebooting the system, we'll let you know it needs to be rebooted so you can do it without disrupting your network.
