mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
Cecilia
Sep 21, 2010Aspirant
Grievous wrote: Alright guys, the good news is that with the help of some of you we were able to get the info we needed. The not so great news is that I don't have a build with a fix for you guys yet, but it will be taken care of in a future build.
Is there any chance that someone could 1. tell me where to download a working firmware for my readynas pro, and 2. tell me if there's something special I have to do in order to "downgrade."
Support told me to downgrade without supplying a single instruction. :( Even if I did locate someplace to download old firmwares, I'd have no idea which one to downgrade to.
