mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mdgm-ntgr
Sep 21, 2010NETGEAR Employee Retired
Try downgrading to 4.2.11. Notes are here: http://www.readynas.com/RAIDiator_x86_4_2_11_Notes
Download the image linked to on that page and install it via System > Update > Local in Frontview.
