mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
beisser1
Sep 21, 2010Tutor
Grievous wrote: Alright guys, the good news is that with the help of some of you we were able to get the info we needed. The not so great news is that I don't have a build with a fix for you guys yet, but it will be taken care of in a future build.
great news. i hope that future build also fixes the cpu-fan beeing turned off on beta-units :)
