mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
Jedi_Knight
Sep 30, 2010Tutor
mule wrote: Issue seems to be fixed after doing some tests with the new beta fw 4.2.14-T13. Many thanks to the Jedi Council!
You are welcome. Keep us update with how it goes.. Thanks.
