mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
lisster
Oct 01, 2010Aspirant
mule wrote: Issue seems to be fixed after doing some tests with the new beta fw 4.2.14-T13. Many thanks to the Jedi Council!
How would i go about trying that firmware to? I was about to downgrade to 4.2.11 on tech supports suggestions but i rather upgrade to a new version to try out
if that is possible. I have a full backup of my readynas that i update by rsync each nite so im not to worried about issues :)
