mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mdgm-ntgr
Oct 01, 2010NETGEAR Employee Retired
Install the update from the Announcement in the Public Beta forum (see http://readynas.com/forum/viewtopic.php?f=51&t=45827) via System > Update > Local in Frontview.
