mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
lisster
Oct 18, 2010Aspirant
Just wanted to update this.
After installing and running tests with the new 4.2.15 firmware so far my fan issues seem fixed.
Alas my read speed issues seem to still be exactly the same :(
Was there anything found out and/or done about it in this firmware or is that still coming?
