mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mdgm-ntgr
Oct 18, 2010NETGEAR Employee Retired
As this isn't really relevant to this thread, you should open a separate thread for your read speed issue and probably open a technical support case as well.
