mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mromanch
Jan 04, 2011Aspirant
So I'm sitting here doing nothing on the NAS and I hear the fans start howling. The thing is reporting 75C on the OLED. I haven't used it all day and it wasn't doing any of the scheduled tasks. (Not sure if there are other small maint tasks it does that don't have specific setup.)
Funny things:
A) First report in logs is AT 75.5C, nothing before that.
B) In status view on both Radiator and browser app, the temp shows green. In the browser app, mousing over the temp got me an empty white box. Now the fans have settled down and mousing over shows temp at 47 & 40C.
C) In about 60 seconds temp 2 when from some value less than 60 to 75.5C then down to 40C?!?
Funny things:
