mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
PapaBear1
Jan 05, 2011Apprentice
mromanch wrote: Can somebody at least let me know what temperature sensor 2 is measuring?
It is the case or general system temp.
Edit 1/19 - I stand corrected - s/b CPU temp.
