mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
topo_nas
Jan 07, 2011Aspirant
My question stands. If your chassis fan cannot remove the hot air, the CPU fan will have to work harder and the CPU could run hotter.
