mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
sphardy1
Sep 27, 2011Apprentice
rickwookie wrote:
I have a new ReadyNAS Pro 6 and I'm getting constant warnings regarding the Temp SYS hitting 66C.
If it was a firmware issue we'd likely be seeing multiple people reporting virtually identical symptoms, which we're not.
So I'd be suspicious there is a hardware issue with your NAS & I'd strongly recommend you contact Netgear directly. If the unit is new you have 90 days telephone support from Netgear.
