mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
spiderman1
Jan 10, 2012Guide
o, can anyone else running the latest beta take a look at theirs? Or anyone else with a Pro 6? This feels like a firmware error, but if it's a hardware error, I'd like to know before I get too far along setting up my system.
Tech support has confirmed that it is a firmware error. This is based on my own case which I had opened with them two months ago.
Have you tried upgrading with T23 beta? This has corrected the problem for me.
