blushark
Mar 12, 2022Aspirant
ReadyNas RN102 has no power but usb does
So I got home from vacation and my ReadyNas RN10223D was powered off. I tried everything, but I could to get it to turn on...no lights anywhere and no fan. I swapped out another ReadyNas power supply brick plug and still did not work. The only thing that works is the usb for light power (i.e. charging head phones).
Is there something inside the Chassis that I can easily replace or can I find a similar unit I can just buy and insert my current drives and have access to my drives? I have a mirrored RAID-1 set up for the two drives.
If I can't just buy a similar or exact model, is there software out there that allows me to access the drive to read and transfer the data off to another storage source?
I know the drives are good b/c I plugged in one of the dries to an external HDD drive bay and pulled it up in the Disk management of Windows Computer Management configs. I could see the volume and it showed all three partitions as healthy, but I could not assign it a drive letter to pull in up in windows explorer. I have been meaning to upgrade to a new NAS machine, but just been lazy about it. I know this model RN10223D goes back to 2013 and I was on borrowed time.
I have a Windows 7 machine.
Thanks for any help or guidance on this.
What model ReadyNAS did the second brick come from?
The disks can be directly migrated to any OS-6 ReadyNAS.
That is normal, because Windows doesn't include support for mdadm RAID or the BTRFS file system.
However, there are open-source packages for both mdadm and btrfs that you could try.
