Obiwan_
Feb 05, 2023Apprentice
ReadyNas RN2304 Using Large capacity SSD (16TB) connected to USB
I have four RN2304s with max capacity on one of 28TB. I have been trying to set up backups using attached USB drives. So far I have used mechanical USB drives to capacity of 5TB without any problem. I purchased some 16TB SSD usb drives and the NAS would not mount them. I tried various formats (NTFS, exFat, etc) without success. I then started reducing the size of the drive and reached 1.25TB (MBR:NTFS) and it sees the drive. Has anyone had success with larger SSDs? Any suggestions?
Thanks
- SandsharkSensei
The ReadyNAS OS does not support ExFAT, so don't keep trying that. It should support GPT/NTFS without regard to it being an SSD or mechanical hard drive. But it does not support a drive having a GPT protective partition. When it does show up, what happens if you try to reformat with the NAS?
