aegon
Mar 10, 2021Aspirant
Readynas to pc and internet connection
Hi All
Apologies if this is in the wrong place, first time. I hope someone can help me.
This is the setup.
PC is connected to the Internet via wifi (cannot run any network cables)
I have connected the ReadyNAS RN31400 to the PC's nic with a Ethernet cable (only one nic on the pc)
I can access the ReadyNAS - all good.
question. - how do i get the ReadyNAS to connect to the Internet?
Before anyone says connect it directly to the router i cannot, and not possible at the moment.
i have looked and researched and i cannot find a way.
Appreciate any help with this.
Hi All
Thank you for replying i really appreciate it. i did find a solution. But first only fair to answer the questions;
*the router is downstairs front room, at the moment i cannot run a cable to the upstairs backroom where i use my computer.
*not appropriate at the moment to keep the nas near the router as i do not have space and sockets.
*im using a pc windows 10
any as StephenB mentioned - i shared my wifi connection with the Ethernet connection and works great, i did not even know it possible .. i did try it a few times did not work, but after resetting and then trying again it worked. and is working great.
this is the link i found: https://youtu.be/xpTO0zaeqiY
Can you explain more? Are you saying that
- you don't have physical access to the router?
- the router doesn't have any ethernet ports?
- there's not enough space near the router for the NAS?
- something else???
Also, is this a Windows PC or a Mac? What version of Windows or MacOS are you running?
- SandsharkSensei
A WiFi access point is one possibility.
And Powerline networking.
Internet connection sharing is also an option with a Windows PC (not sure about MacOS).
Still, connecting it to the router is preferrable, so it would be helpful to get more details on why that can't be done.
- aegonAspirant
Hi All
