avientit
Feb 12, 2013Follower
ReadyNAS Ultra 2 - Suddenly inaccessible over network
Hi all, I have a ReadyNAS Ultra 2 with firmware RAIDiator 4.2.22 on it. I have set this little box up for testing purposes and it seems to have been working fine. It is connected to a switch wit...
EBrown95831
Feb 13, 2013Aspirant
I would start by clearing the active sessions via the (net use /delete *) command and then try remapping the drives/shares. I would also try disconnecting the lan cable from the readynas while running a continuous ping to it to see whether this is being caused by an ip address conflict due to a dhcp server, sounds silly but Ive seen this be the cause of the issue more times than you can imagine
