GAPP
Dec 06, 2012Aspirant
ReadyNAS Ultra 2 as Media Server
Hello, I have to admit, that I'm not really a veteran on these matters, but I want to learn. The idea is to have a NAS that I can use as media server. It needs to be fast enough to not cause pro...
Dec 07, 2012Guru - Experienced User
That would be a good solution. If you also want to use DLNA with transcoding, the best option would be Pro-6 (using plex). For straight streaming, the ultra 6 should work nicely. You probably don't want it in the same room as the home theater, since the fan will be audible. You could construct a baffle if that is essential (I saw a blog entry somewhere from someone who had done that with a ReadyNAS).
It is fine to mix hard drives, though keep in mind that future hard drives would need to be 3 TB or larger.
The default XRAID-2 raid configuration would work nicely, just make sure you install all 3-4 initial drives together (don't start with one and then add the others, that will limit your expansion later on).
