GAPP
Dec 06, 2012Aspirant
ReadyNAS Ultra 2 as Media Server
Hello, I have to admit, that I'm not really a veteran on these matters, but I want to learn. The idea is to have a NAS that I can use as media server. It needs to be fast enough to not cause pro...
GAPP
Dec 09, 2012Aspirant
Absolutely correct. Almost all of them are .mkv files, which seems to be supported on just about any mediaplayer (TV's etc). Will I have a problem with transcoding on the fly, with the Ultra 4? I mean, I don't know if it will happen enough to even consider changing the setup, but just to know.
I'm not sure where I should have it located, but I guess I can put it in the office or I'll make some kind of device if that's too much. The noise problem shouldn't be a huge prroblem, though of course it would be nice having a silent one. :)
Do you use Plex for the media center?
