GAPP
Dec 06, 2012Aspirant
ReadyNAS Ultra 2 as Media Server
Hello, I have to admit, that I'm not really a veteran on these matters, but I want to learn. The idea is to have a NAS that I can use as media server. It needs to be fast enough to not cause pro...
TeknoJnky
Dec 09, 2012Hero
well, the readynas builtin media server does not trancode, you would need the plex server or some other addon that can transcode.
I'm not sure if the ultra 4 will be powerful enough to transcode bluray in real time, but I am doubting it.
You would only need transcode for media clients that can not already handle the mkv/bluray rips, for clients that do not need transcoding the u4 will be fine.
the ultra4 has this (or similar spec) cpu
53: None 00.0: 10103 CPU
[Created at cpu.305]
Unique ID: rdCR.j8NaKXDZtZ6
Hardware Class: cpu
Arch: Intel
Vendor: "GenuineIntel"
Model: 6.28.10 "Intel(R) Atom(TM) CPU D410 @ 1.66GHz"
Features: fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,ps e36,clflush,dts,acpi,mmx,fxsr,sse,sse2,ss,ht,tm,pbe,syscall,nx,lm,constant_tsc,a rch_perfmon,pebs,bts,rep_good,nopl,aperfmperf,pni,dtes64,monitor,ds_cpl,tm2,ssse 3,cx16,xtpr,pdcm,movbe,lahf
Clock: 1662 MHz
BogoMips: 3324.66
Cache: 512 kb
Units/Processor: 2
Config Status: cfg=new, avail=yes, need=no, active=unknown
