GAPP
Dec 06, 2012Aspirant
ReadyNAS Ultra 2 as Media Server
Hello, I have to admit, that I'm not really a veteran on these matters, but I want to learn. The idea is to have a NAS that I can use as media server. It needs to be fast enough to not cause pro...
gibxxi
Dec 15, 2012Guide
XBMC is infinately more configurable than Plex. Plex is a Media Centre software which will be easier to maintain if the WAF (Wife Approval Factor) is an important consideration, or you want something that requires a minimal amount of tinkering or configuration, and you don't desire advanced functionality or add-ons.
XBMC is a better solution if you want advanced features, and don't mind tinkering to get a desirable end result. XBMC also differs from Plex in that each client is a standalone entity (unless your using MySQL Db sharing), whereas Plex uses a central, headless, server application to which each client connects.
Powerline feasibility depends largely on the structure and age of the wiring in your home. If you have old wiring and/or seperate ring-mains, it may be a less attractive option than Wireless. My place is a relatively new build, with a single ring-main, and Wireless performance for me was borderline because of interference. Each system (Wireless vs. Powerline) depends on your individual needs, circumstances, and surroundings.
