villa1
Dec 18, 2014Tutor
READYNAS Ultra 2 looses network connectivity
Hi, Im having an issue with the network connection of my ReadyNas DUO Ultra 2. When I start copying files into the NAS device, it looses network connectivity and it disappear from network. Neith...
vandermerwe
Dec 18, 2014Master
I would just clarify with support, before paying, that the extended support contract would actually lead to a RMA if a hardware fault is diagnosed.
You also need to do some calculations to figure out whether it may be cheaper in the long run to buy a new readynas.
