villa1
Dec 18, 2014Tutor
READYNAS Ultra 2 looses network connectivity
Hi, Im having an issue with the network connection of my ReadyNas DUO Ultra 2. When I start copying files into the NAS device, it looses network connectivity and it disappear from network. Neith...
villa1
Dec 18, 2014Tutor
Hi vandermerwe,
thanks for you suggestion. Support has already replied.. even adquiring 3 more years support it does not cover HW replacement (not sure exactly why when I'm paying three more years of support). I've asked if there is a way to buy only the faulty part (PCI card dual network), I don't like to throw a device when it has replacement parts for that. Three years of support is cheaper than buying a new one, I don't have to buy a new device and I can replace it in short time.
This is info taken from OS6 dmesg after retart the device also after loose again the network copying over the only available interface (eth0). Similar errors to those I've seen with RAIDIator 4.2.X version.
I cannot find errors in log file referred to eth0, but I guess the below errors caused the failure of eth0 too.
after 235 eth1 Errors.
Really there isn't a way to buy the PCI express card?
eth0: Marvell Yukon 88E8057 Gigabit Ethernet Controller
PrefPort:A RlmtMode:Check Link State
sk98lin 0000:03:00.0: enabling device (0000 -> 0003)
sk98lin 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
sk98lin 0000:03:00.0: setting latency timer to 64
eth1: Marvell Yukon 88E8057 Gigabit Ethernet Controller
eth1: -- ERROR --
Class: Hardware failure
Nr: 0x272
Msg: Uncorrectable PCI Express error
eth1: -- ERROR --
Nr: 0x272
eth1: -- ERROR --
Nr: 0x272
eth0: network connection up using port A
speed: 1000
autonegotiation: yes
duplex mode: full
flowctrl: none
irq moderation: disabled
tcp offload: enabled
scatter-gather: enabled
tx-checksum: enabled
rx-checksum: enabled
rx-polling: enabled
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0: network connection down
ADDRCONF(NETDEV_UP): eth0: link is not ready
speed: 1000
duplex mode: full
flowctrl: none
rx-polling: enabled
eth0: no IPv6 routers present
