villa1
Dec 18, 2014Tutor
READYNAS Ultra 2 looses network connectivity
Hi, Im having an issue with the network connection of my ReadyNas DUO Ultra 2. When I start copying files into the NAS device, it looses network connectivity and it disappear from network. Neith...
vandermerwe
Dec 18, 2014Master
Do you get the same errors when you connect directly to the nas from your pc?
You are using ip4 addresses?
