villa1
Dec 18, 2014Tutor
READYNAS Ultra 2 looses network connectivity
Hi, Im having an issue with the network connection of my ReadyNas DUO Ultra 2. When I start copying files into the NAS device, it looses network connectivity and it disappear from network. Neith...
Nhellie
Dec 18, 2014Virtuoso
apparently the reason why support can't extend your hardware warranty is because you device is already on this list. :(
http://netgear.com/landing/eol.aspx
I have heard that once your product is listed there, all you can do is upgrade to the newer model. ah bummer.
