villa1
Dec 18, 2014Tutor
READYNAS Ultra 2 looses network connectivity
Hi, Im having an issue with the network connection of my ReadyNas DUO Ultra 2. When I start copying files into the NAS device, it looses network connectivity and it disappear from network. Neith...
vandermerwe
Dec 18, 2014Master
I don't understand why you would want to buy a replacement for an EOL product. Even if you find one to buy, it will have 0 warranty. The risk is then that you will have another hardware problem and be stuck back where you are now. It could end up costing you even more than a new readynas.
