howsk's avatar
howsk
ReadyNAS Ultra 2 PLUS - discontinued?
Hi
I'm trying to buy the ReadyNAS Ultra 2 PLUS in the UK, but cannot find it anywhere. Every online store shows no stock available and most say they do not know if they will be getting any more stock. Only option seems to be to buy from the US and then pay import tax.
Does anyone know if this model is now discontinued or is there a replacement on its way?
I am specifically looking for the PLUS (Dual Core Intel) and not the regular Ultra 2 (Single Core).
Thanks in advance
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Have you tried looking for the Pro 2 (same CPU as Ultra 2 Plus but with longer warranty and more features)?
    @ mdgm
    I had no idea that the pro series did a 2 disk NAS in a similar footprint to the duo / ultra 2. Have always been looking at the home user / prosumer section. This is perfect and I already sourced and bought online!
    Many thanks!
ProSupport for Business
