blueray1
Jul 26, 2011Aspirant
ReadyNAS Ultra 2 Plus vs RNDP2000
Warranty replaced my ReadyNAS Ultra 2 Plus (RNDP200U) with model RNDP2000-100NAS. What are the differences? Will the TiVo server still function in in the RNDP2000? Photos II?
Thanks
Thanks
- mdgm-ntgrNETGEAR Employee RetiredPro 2 (RNDP2000) is a business model and has business features (e.g. NIC Teaming/Bonding, Windows Domain integration, Rsync over SSH) and a 5 year warranty (however since your unit is a replacement under warranty I believe your original 3 year warranty would continue).
It will do everything your old unit could do plus more. - blueray1AspirantThanks for the info. Will it be safe to just move my data disks from the Ultra 2 Plus to the RNDP2000 and boot? -Or will the difference in model number cause me to loose data when booting in the RNDP2000?
blueray wrote: Thanks for the info. Will it be safe to just move my data disks from the Ultra 2 Plus to the RNDP2000 and boot? -Or will the difference in model number cause me to loose data when booting in the RNDP2000?
Migration will work fine. They are both x86 ReadyNAS. See http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
If you have a spare disk (not from your array), I'd suggest you put that disk in the Pro 2, do a factory reset (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) if necessary, update the firmware to the same version you had on the Ultra 2 Plus or later, then power down, remove the spare disk and follow the migration procedure outlined in the FAQ link above. - warlock1AspirantWith Pro devices You get ProSupport and your cases can be handled within 24h SLA
- ecalonllcAspirantdoes the RNDP2000 support iSCSI targets?
ecalonllc wrote: does the RNDP2000 support iSCSI targets?
Yes, the Pro-2 supports iSCSI targets as does the Ultra 2 (+).
http://www.readynas.com/?cat=49
