irishkeet
Sep 11, 2010Tutor
ReadyNAS Ultra 4 92mm Fan spec
Hello
FYI
This is the exact fan used in the Ultra 4.
http://www.cwc-group.com/afb0912hh.html
Descriptions / Features / Specifications
Delta AFB0912HH 92x25mm 3-Pin Fan, P/N: AFB0912HH
# Connector: 3-Pin & 3-Wire
# Dimensions: 92 X 92 X 25 mm (3.6 X 3.6 X 1 in)
# Power: 12 VDC (7.0 to 13.8) 0.4 Amp
# Speed: 3200 RPM
# Max Air Flow: 57.92 CFM
# Noise Level: 38 dBA
cheers
irishkeet
FYI
# Speed: 3200 RPM
cheers
irishkeet
1 Reply
- bodiedooAspirantTY
