fondy
Apr 17, 2017Tutor
ReadyNAS Ultra 4 and defect HD
Hi I have four Seagate st2000dl003-9vt166 2TB in my ReadyNAS Ultra 4, and one of these is dead. These Seagate disks can not be found no more. Can I use another Segate 2TB disk, example Seagate ...
- Apr 17, 2017
We'd recommend checking the compatibility list. On the compatibility list page you'd select Legacy then Ultra 4
fondy
Apr 19, 2017Tutor
I have this Raid config:
Apr 19, 2017Guru - Experienced User
disk 2 is also marked as spare.
If you have backup (or are ok with data loss), the the simplest answer is to do a factory reset, rebuild the NAS, and restore the data from the backup.
If you have no backup, then you probably should contact paid support (my.netgear.com). Per-incident support might be enough, though this might need data recovery (which is expensive).
You could also try something like ReclaiMe on your own - also expensive, but you should be able to see what can be recovered before you buy.
- fondyApr 19, 2017Tutor
Hi, thanks for your reply
yes I have backup. But before factory reset, I took theUltra4 down with pressing the power button twice.
The new disk in slot4 out
The old and defect disk back in slot4
Pressed the powerbutton and starting the Ultra4
And now all seems ok :)
- StephenBApr 20, 2017Guru - Experienced User
I'd check the SMART stats for each disk anyway.
Given these misbehaviors, I think it's particularly important to keep your backup up to date.
- fondyApr 23, 2017Tutor
Hi
Have factory reset the Readynas, upgraded Radiator to the latest 4.2.30 and restored all the data from backup
Paal
