lefjomp
Dec 28, 2011Aspirant
readynas ultra 4 and wd disks?
hi! i have finally uppgraded from a readynas duo to a readynas ultra 4, i heavent installed it yet because im waiting for a 2tb harddrive that i ordered,its an usb drive from western digital, insid...
bbaraniec
Dec 28, 2011Luminary
They are compatible with Duo so I would guess they should work with ultra as well.
You should also check users HCL for more info. As for speed between Duo and Ultra you will not be disappointed :)
