lefjomp
Dec 28, 2011Aspirant
readynas ultra 4 and wd disks?
hi! i have finally uppgraded from a readynas duo to a readynas ultra 4, i heavent installed it yet because im waiting for a 2tb harddrive that i ordered,its an usb drive from western digital, insid...
lefjomp
thank you for a quick reply, i also noticed that the WD20EARX is compatible with the duo, but it was not listed in the ultra list, it might be a old list?
what do you mean by check users HCL ?
later when i have installed the new ultra with the new hd inside, what is the easiest what to do when i need to transfer 1,7 tb from my old duo to the ultra?
thanks
lefjomp
thanks
lefjomp
