lefjomp
Dec 28, 2011Aspirant
readynas ultra 4 and wd disks?
hi! i have finally uppgraded from a readynas duo to a readynas ultra 4, i heavent installed it yet because im waiting for a 2tb harddrive that i ordered,its an usb drive from western digital, insid...
Dec 28, 2011Guru - Experienced User
try creating the shares manually on the ultra-4, and then use the frontview backup facility on the ultra to copy the data. You can do this share by share. I suggest running one backup job at a time (frontview will let you run them all in parallel, but personally I think it is better not to do that).
lefjomp wrote: later when i have installed the new ultra with the new hd inside, what is the easiest what to do when i need to transfer 1,7 tb from my old duo to the ultra?
NFS is the fastest protocol for copying NAS to NAS, so you might want to enable it on the duo and the ultra first.
