dsteak
Sep 20, 2014Aspirant
ReadyNAS Ultra 4 with 4TB
I have the ReadyNAS Ultra 4, have been running 2x2TB for 3 years, and I recently threw in a 4TB drive in slot 3 (HGST Ultrastar 7K4000 HUS724040ALE640). It recognized fine and did the expansion, howe...
vandermerwe
Oct 06, 2014Master
Have you heard of wdidle3?
What model wd disks are you using?
Are the other smart stats for the 3 wd drives ok?
If you need to expand that's a good reason to replace the disks, I wouldn't do it simply because of the load/ unload cycles.
