dsteak's avatar
dsteak
ReadyNAS Ultra 4 with 4TB
I have the ReadyNAS Ultra 4, have been running 2x2TB for 3 years, and I recently threw in a 4TB drive in slot 3 (HGST Ultrastar 7K4000 HUS724040ALE640). It recognized fine and did the expansion, however I'm showing 3 X 2TB (3 X 1863), not 2 X 2 and 1 X 4. Should I have not used a 4TB drive to expand? This one is on the supported list. Is that 2TB unusable?
RAIDiator 4.2.26
  • StephenB's avatar
    crond wrote:
    StephenB wrote:
    crond - 4x4TB would give you a 12 TB volume (10.9 TiB). So if your initial volume size (last default or initial install) was less than 2.9 TiB, then you would hit the 8 TiB growth limit..
    my initial install was 4x2tb in raid5 -> 6tb total. I'm happy with raid but it's been up and running for over 3 years nonstop and Load/unload cycles on disks are over 1.2M or 400% of what WD recommends and warranty ended this month, so time to change them before they fail. I'm thinking about going with 4tb which should give me 12tb, so theoretically I should be able to replace disks and grow volume. I guess it will take me a week+ to replace disks one by one / rebuild raid5 / grow volume.
    Do you know any side effects or caveats that I should be aware of ?
    Thanks!
    I have 4 old green drives that are in my NV+, which have lots of load cycles also. That's just for backup, so I haven't worried about it.
    You should be able to execute this plan, though of course backups are always advisable when manipulating disks. If you do make a full backup, you could do a clean factory install with all 4 new drives in place. It could turn out to be faster than 4 hot-inserts and resyncs.
    vandermerwe - wdc's position - at least for a while- was that using wdidle3 would void your warranty. Though I never heard of them enforcing it.
  • Given that the Ultra 4 is a legacy product now, is there any hope of more 4 TB HDDs being added to the compatibility list? There's only one on there now (Hitachi). I'm looking at the Seagate NAS HDD ST4000VN000 4TB, which is on sale now. I have 4x 3 TB Hitachi Deskstars in my Ultra 4, and after the latest RAIDiator update I got a reallocated sector. Count hasn't increased in the past week, but I'm thinking about expanding to 4 TB drives. I might be willing to take a chance on these Seagate drives, esp. if someone with knowledge and experience thinks they should work.
    TIA.
ProSupport for Business
