kzabak
Nov 15, 2011Aspirant
readynas ultra 6 cpu
hey
i would want to buy a readynas ultra 6, after the thecus 7700pro was.. well... a joke,..
now i have a really good price for it, but the traders webpage states that the nas only has a single core atom 1,66ghz, not a dual, as the specs on the readynas site say.
now i guess that new version have been shipped, before with single-after with dual core?!?!
when was that?!?
what difference in performance will the single have to the dualcore? ok yeah-double the cores, but lets say at what point of usage would the single core be overstressed?
i will have 24/7 bt, musicserver running, and when playing video from it, i will use a netbook (will the netbook do the transcoding then and the nas is only datasupplier?) and not a dnla player or sth, where the nas has to do all the work...
might i be happy with the single core?
my2cents-they should have a new model number when a new cpu is put in... its a realy mess to find out which of all these RNDU6000-100PES has which cpu in it
any help would be appreciated
when was that?!?
- kzabakAspirantyeah wasnt clear enough...
i will always have a proper player..meaning a netbook....
i hate these transcoding problems and reservations and what not
a netbook can do it all...
record, playback, internet, music, data and so on
i dont get why ppl buy these media sset top players at all
ok only field i would trust is a webradio with network playback
since mp3 is a set standard nowadays i would have no problem, but video is not set at all and will not be
i was looking into the 1015n eepc, but heard there was one with non-glare screen, but since i have no server i didnt follow...;)
will order the readynas now... sounds all good - kzabakAspiranti ordered today from another shop-the other ran out....
so 1 more q:
i bought a RNDU6000... is there a difference to a RNDU6000-PES?
ehat does the suffix mean? - mdgm-ntgrNETGEAR Employee RetiredThe PES would be the region code indicating the language of included documentation and stuff like that. It's still exactly the same device.
While the PSU is custom, the Ultra 6 uses a standard PC power cable. One would think you'd get a power cable for your region (assuming you purchased locally), but if not they're pretty cheap to purchase if you don't have any spares lying around. - kzabakAspirantgreat support again - thx a lot for helping making my decision to all..
will give feedback when (hopefully not) running into any probs
cheers - kzabakAspirantjust for feedback-got a ultra6plus for really cheap money and am very happy for now-thx again
