krid
Jul 31, 2019Aspirant
ReadyNAS Ultra 6 "hangs"
My trusty ReadyNas Ultra 6 has stopped working :( It is booting fine but it seems anything needing i/o is stuck in an endless loop. The GUI prompts for username/password but after that it keeps loadi...
- Aug 02, 2019
krid wrote:
Looks like my reply was deleted... if a mod thinks I did something wrong, please tell me what it was?
Probably it just got caught in the automatic spam filter.
krid wrote:
I'm running firmware 4.2.31
OS is 45% used and C is 80%
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 4184756 1780800 2194296 45% /The OS is fuller than usual, but not dangerously so. With no apps installed it is usually about 20-25%
Does ls -la hang in the OS partition, the C volume or both?
It might be worth trying an OS reinstall via the boot menu.
krid
Aug 01, 2019Aspirant
Thanks for responding!
It's running RAIDiator-x86 Version 4.2.31
OS partition is OK?
/dev/md0 4184756 1781148 2193948 45% /
tmpfs 16 0 16 0% /USB
/dev/c/c 9699971712 7694711664 2005260048 80% /c
/c/home 9699971712 7694711664 2005260048 80% /home/ftp/homes
NAS:/var/log# cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 sda5[0] sdf5[5] sde5[4] sdd5[3] sdc5[2] sdb5[1]
9743960960 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU]
md1 : active raid5 sda2[0] sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1]
2621120 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU]
md0 : active raid1 sda1[0] sdf1[5] sde1[4] sdd1[3] sdc1[2] sdb1[1]
4193268 blocks super 1.2 [6/6] [UUUUUU]
