krid
Jul 31, 2019Aspirant
ReadyNAS Ultra 6 "hangs"
My trusty ReadyNas Ultra 6 has stopped working :( It is booting fine but it seems anything needing i/o is stuck in an endless loop. The GUI prompts for username/password but after that it keeps loadi...
- Aug 02, 2019
krid wrote:
Looks like my reply was deleted... if a mod thinks I did something wrong, please tell me what it was?
Probably it just got caught in the automatic spam filter.
krid wrote:
I'm running firmware 4.2.31
OS is 45% used and C is 80%
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 4184756 1780800 2194296 45% /The OS is fuller than usual, but not dangerously so. With no apps installed it is usually about 20-25%
Does ls -la hang in the OS partition, the C volume or both?
It might be worth trying an OS reinstall via the boot menu.
krid
Aug 02, 2019Aspirant
Anyway, thanks (again) for replying. I'm running firmware 4.2.31
- StephenBAug 02, 2019Guru - Experienced User
- kridAug 07, 2019Aspirant
Yes, it was hanging on both partitions. Strangly enough I was able to copy the custom apps to USB so I decided on your suggestion to do an OS reinstall. Now it's fixed. Thanks for help!
