warchucky
Mar 13, 2015Aspirant
Readynas ULTRA 6 Harddrive 6TB
hello all can i put 6x WD RED 6TB in my readynas ultra 6? greetings
Mar 13, 2015Guru - Experienced User
It should work, but you will need to do a factory reset with all drives in place (or insert all drives into the NAS and just power up).
If you are going to do this, you might consider switching to OS6 while you are at it. That would let you expand when the even bigger drives come along.
