warchucky
Mar 13, 2015Aspirant
Readynas ULTRA 6 Harddrive 6TB
hello all can i put 6x WD RED 6TB in my readynas ultra 6? greetings
RX
Mar 18, 2015Luminary
warchucky wrote: can i install 6x 6TB disks on RAIDiator 4.2.27?
what is the diskspace limit on 4.2.27?
I believe that you could use 6x6TB disks using RAIDiator v4.2.27. Just make sure that you perform a factory reset with all 6x6TB disks in place as per advised by StephenB.
As reference for the disk space limit (or rather volume limit), check this forum thread: viewtopic.php?f=66&t=79374
