warchucky
Mar 13, 2015Aspirant
Readynas ULTRA 6 Harddrive 6TB
hello all can i put 6x WD RED 6TB in my readynas ultra 6? greetings
RX
Mar 18, 2015Luminary
warchucky wrote: it seems the ultra6 has a max limit of 16TB, so i cant place 6x 6TB in raid6 cause then i have 24TB
I believe its still possible to support 16TB or greater, you just need to perform a factory reset on your Ultra6 with all 6x6TB disks in place to achieve dual redundancy.
Check info about x86 Legacy ReadyNAS like your Ultra6 regarding 16TB limit on this link: http://www.rnasguide.com/2011/06/22/why ... -readynas/
