warchucky
Mar 13, 2015Aspirant
Readynas ULTRA 6 Harddrive 6TB
hello all can i put 6x WD RED 6TB in my readynas ultra 6? greetings
Mar 18, 2015Guru - Experienced User
Correct. A factory reset with all drives in place will work. All drives need to be the same size, and you can't expand the volume later.
Ixa wrote:
warchucky wrote: it seems the ultra6 has a max limit of 16TB, so i cant place 6x 6TB in raid6 cause then i have 24TB
I believe its still possible to support 16TB or greater, you just need to perform a factory reset on your Ultra6 with all 6x6TB disks in place to achieve dual redundancy.
