delanod
Nov 19, 2013Aspirant
ReadyNAS Ultra 6 Plus Fan Noise
I have a ReadyNAS Ultra 6 Plus with the latest firmware. On a fresh boot, the fans resolve to an acceptable level. However, after running for a while, the fans are suddenly at full blast, and I can'...
delanod
Nov 21, 2013Aspirant
I have the firmware updated to the latest, whatever that is. RAIDar says 4.2.24. This is a fairly new unit, and I haven't modded anything on it. I don't think it's a dust or temperature issue, since it runs fine after a reboot. I'll have to check the temperature and speed when it goes into overdrive again, probably Sunday. Currently, the health parameters are:
Fan SYS 1188 RPM OK
Fan CPU 2280 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 39.5 C / 103 F [Normal 0-85 C / 32-185 F]
The unit is currently as quiet as my desktop, which runs very quiet with temperature controlled fans, and an SSD that is noiseless.
David
Fan SYS 1188 RPM OK
Fan CPU 2280 RPM OK
David
