delanod
Nov 19, 2013Aspirant
ReadyNAS Ultra 6 Plus Fan Noise
I have a ReadyNAS Ultra 6 Plus with the latest firmware. On a fresh boot, the fans resolve to an acceptable level. However, after running for a while, the fans are suddenly at full blast, and I can'...
delanod
Jan 12, 2014Aspirant
It took a while, but the problem appeared again today. The fan noise was way up this morning, but maintenance was not complete, so I ignored it. Now, however, the maintenance has been complete for about 10 hours and the fan noise is still up. Note that the CPU fan is running about twice the speed, and the CPU temperature is up.
Device Description Status
Disk 1 Seagate ST1000DM003-9YN162 931 GB , 39 C / 102 F , Write-cache ON OK
Disk 2 Seagate ST1000DM003-9YN162 931 GB , 42 C / 107 F , Write-cache ON OK
Disk 3 WDC WD30EFRX-68EUZN0 2794 GB , 42 C / 107 F , Write-cache ON OK
Disk 4 WDC WD30EFRX-68EUZN0 2794 GB , 41 C / 105 F , Write-cache ON OK
Disk 5 WDC WD30EFRX-68EUZN0 2794 GB , 40 C / 104 F , Write-cache ON OK
Disk 6 WDC WD30EFRX-68EUZN0 2794 GB , 38 C / 100 F , Write-cache ON OK
Fan SYS 1250 RPM OK
Fan CPU 4560 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 50.5 C / 122 F [Normal 0-85 C / 32-185 F] OK
UPS 1 Not present NA
So, the fan is cooling as it should, but something is driving the CPU temperature up. Is there any way to tell what is running that might be causing excessive CPU usage?
David
Fan SYS 1250 RPM OK
Fan CPU 4560 RPM OK
David
