delanod
Nov 19, 2013Aspirant
ReadyNAS Ultra 6 Plus Fan Noise
I have a ReadyNAS Ultra 6 Plus with the latest firmware. On a fresh boot, the fans resolve to an acceptable level. However, after running for a while, the fans are suddenly at full blast, and I can'...
fastfwd
Jan 12, 2014Virtuoso
delanod wrote: something is driving the CPU temperature up. Is there any way to tell what is running that might be causing excessive CPU usage?
If you have SSH access to the NAS, you can use the "top" command to see a list of running processes sorted by CPU usage.
