delanod
Nov 19, 2013Aspirant
ReadyNAS Ultra 6 Plus Fan Noise
I have a ReadyNAS Ultra 6 Plus with the latest firmware. On a fresh boot, the fans resolve to an acceptable level. However, after running for a while, the fans are suddenly at full blast, and I can'...
fastfwd
Jan 12, 2014Virtuoso
delanod wrote: Do I need to have something installed on the NAS to have SSH access?
Yeah, you need this addon: http://www.readynas.com/?p=4203 (choose the "x86" version).
When you connect via SSH, your username is root and your password is the same as your Frontview admin password.
At the "#" prompt, type top to see the list of active processes; when you're done, hit Q to quit top and then type exit at the "#" prompt to close your SSH session.
