gpu
Sep 25, 2012Follower
ReadyNAS Ultra 6 Plus questions
Hello ! I am looking for more informations concerning the ReadyNAS Ultra 6/Plus. Context : I plan to buy this NAS + 2 x 3To WD Red I plan to start with two 3To WD Red, then up to four 3To d...
Sep 25, 2012Guru - Experienced User
BluRay video is compressed using H.264 High Profile or VC1; actually you will not find much uncompressed HD video out there. Uncompressed 1080p @ 24 frames per second takes over a gigabit/second of bandwidth, and a typical movie would require about 1 TB of space.
vandermerwe wrote: I use Dune HD Smart D1 which is superb with uncompressed HD video including bluray.
