PerfectOnline
Dec 09, 2018Tutor
ReadyNAS Ultra restriping.
Hello fellow NAS-owners, i hope i post this in the right section. Anyways, long story short: i recently made a factory default on my NAS with 5 WD Red 3tb disks in it. After that i started to co...
Retired_Member
Dec 10, 2018PerfectOnline wrote "the power went out (the washing machine does this from time to time)"
To eliminate the root cause for your outages, you might not only want to look for a ups as recommended by StephenB, but also consider to have a decent washer :-)
Kind regards
Dec 10, 2018Guru - Experienced User
Sounds more like there might be a wiring issue or an overloaded circuit to me. If this happens fairly regularly, it would make sense to have an electrician take a closer look.
- PerfectOnlineDec 10, 2018TutorThanks for the reply guys.
Yeah, i will definately report this to the landlord (it’s a rental so it’s free service).
Strange that it does it from time to time and not all the time, seems to always be when there are only a couple of minutes left on the program. Anyways, it will be reported, the dryer is dead too so merry christmas to the owners 😁.
The NAS finished the striping process and then continued to resync and that went fine as well, am i good now?
I want that good feeling back when it felt like my NAS was like new again, i recently bought two new drives for it (still one left to put in/replace). Is my NAS golden now? Could something else go wrong?
To my surprise it reports 8.1TB, shouldn’t it be more like 10TB? I have 6xWD Red 3TB in RAIDX2 DR.
What UPS do you guise recommend?- PerfectOnlineDec 10, 2018TutorSomething is fishy, i did some basic math and: 6x3=18.
8.1TB available out of 18TB in total? Should 9.9TB serve as security for only 8.1TB?- StephenBDec 10, 2018Guru - Experienced User
If you chose RAID-6/dual redundancy, then 6 TB are used for the parity blocks needed for redundancy. That leaves 12 TB for storage. But the NAS reports in TiB, so it should be reporting 10.9 TB.
It sounds like the expansion didn't happen when you inserted the 6th drive.
