jjcf89_2's avatar
Feb 11, 2022
ReadyNAS x86_64: Failed to fetch packages for 6.10.3
Can't install packages due to repo 403 errors
sudo apt-get upgrade
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/main/pool/l/linux/linux-libc-dev_4.4.190.1_amd64.deb 403 Forbidden
jonathan@dceinas:~$ cat /etc/apt/sources.list
deb https://apt.readynas.com/packages/readynasos 6.10.3 updates apps main
deb http://mirrors.kernel.org/debian jessie main
deb http://security.debian.org/ jessie/updates main
1 Reply
  • I get the same error when trying to install linux-image-extra
    jonathan@dceinas:~$ sudo apt install linux-image-extra
    [sudo] password for jonathan:
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    The following packages were automatically installed and are no longer required:
      libio-socket-ip-perl libnih-dbus1 libnih1
    Use 'sudo apt autoremove' to remove them.
    The following NEW packages will be installed:
      linux-image-extra
    0 upgraded, 1 newly installed, 0 to remove and 123 not upgraded.
    1 not fully installed or removed.
    Need to get 6,501 kB of archives.
    After this operation, 30.7 MB of additional disk space will be used.
    Err:1 https://apt.readynas.com/packages/readynasos 6.10.3/main amd64 linux-image-extra amd64 4.4.190-610030005
      403  Forbidden
    E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/main/pool/l/linux/linux-image-extra_4.4.190-610030005_amd64.deb  403  F
    orbidden
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
ProSupport for Business
